treegump
Romans 3:22-24
I did a search of the forum and didn't find too much information on the closed clutch system and how best to bleed it.
Found this video that might help:
When I put a braided steel line on mine the hose maker had the best way for these systems...
If you still have the steel line this will work on the truck as well, I did mine in a vise then mounted everything, in the truck it is best to remove the slave, make what ever you need to so the plunger rod doesn't come out then do as below...
Fill the clutch reservoir, then slowly push the slave rod all the way in making sure the slave is hanging down so air will go up and out the line, this is a somewhat slow process, do this several times until when you push the slave rod in you don't see bubbles in the reservoir..
Don't get in a hurry if it is in the truck, the fluid will be slow to travel and the air is also slow moving up.. I have the best smooth clutch after this, I tried everything and always had a petal that I didn't like, now, it's like a real clutch should be...
With the later internal slaves it may not work as good as with a external slave...
