Ok back from the second dyno session. This one went much better. We had a good RPM signal off of the Ferret adapter after a little fidgeting around with it. You'll see in one of the graphs that we had a pretty erratic signal for the first two runs (we only printed 1 of the graphs, but you'll see why), but then the last two runs were really nice. Final number: 347 and 599. I'll take it!! For every run we've gotten a really consistent horsepower number. Run 4 had a better torque number than run 3 and that seemed to be because we let it idle for a long time between those runs which must have cooled the intercooler back off. I talked to the operator about inertia versus load cell and he said this dyno only runs in load cell mode. He said that with the tiny rollers this has he can't really hold cars back like a larger one. I also suggested loading the turbo with the foot brake and he said the dyno would act funny if I did that because there would be a spike from when it was not loaded due to me holding it back with the brakes and then an instant torque hit when I released the brakes. We talked about running in overdrive instead of drive to see what that did and we were going to try that, but first he wanted to try it in drive again. He wanted to lower the trigger RPM for the dyno so it would react to the RPM of the engine sooner. This would help load it sooner and build boost sooner.
So that's what we did....and it was a much better pull! I could feel the engine working harder and sooner and it was a longer pull up to the higher rpm. I feel like we have a pretty good setup working now. I think it would still be interesting to run on a dyno that's used to running diesels so I could compare and contrast, but this is going to work just fine for my testing purposes.
I'll attach some pics now. One will be of the exhaust vent tube. So it did end up working well, but interestingly it stretched way out after the first hit! I think the combination of heat and exhaust pressure made it expand. He said the tube itself was smoking pretty good during that first hit. He took a video so I could see during the second hit and this is the only outside video I have because I didn't bring my entourage this time. I also have EGT & Boost videos for all 4 runs which I haven't really looked at myself too much. I did take a quick shot of the fuel pressure gauge at the end of a run too for fun.
So I think I have a solid baseline now. On to more upgrades and future tests now!!
What the vent looked like after the first run
Run number 2, you can see the Ferret was acting up. Love that torque number!!
Run number 3
Run number 4
Videos in a sec.
