Hello all, longtime lurker making first post. Seems there is allot of wisdom here and I would like your opinion on something.
I have an 1997 K1500 Suburban, it has a Superlift K270b 4"-6" lift, BFG 35" Tires. I just completed swapping in a 9.5" 14bolt SF rear with Dual Piston Disc Brakes from a 2002 K1500 Suburban.
The brakes on this truck have never been stellar as you know and I have been reading about swapping in a hydroboost system from a NBS truck. This past weekend I got a Hydroboost system complete from a very clean 2005 Z71 Suburban at the wrecking yard.
After reading through this thread: http://www.thetruckstop.us/forum/th...ng-or-brakes-ps-tank-overflowing.43943/page-3,
I'm wondering if this is a good idea.
While the brakes are not stellar on the suburban, they have always worked and the power steering has been flawless.
By installing the Hydroboost it sounds like I could introduce both steering and braking issues to my truck. I know I need to do something to adjust for the braking bias now that I've added rear disc and I is possible to user the master cylinder from the the 2005 setup alone and get slightly better brakes.
I guess my ultimate question is the hydroboost braking worth the added complexity and addition points of system failure?
I'm a fairly handy with tools and I have know doubt I could install the system properply but sounds like even if I do that, there could be problems.
I'd like to hear from you all what you think and would you do the swap.
Thanks in advance.
David,
Thanks in advance.
David,
