On the front brake clip I worried about it not be exactly like OE but seems to be fine. I have no wear on the line that I can see or feel.
The OE clip lays in a little trough the whole width of the knuckle ( sorta along the blue line). I worried about the backside of line rubbing underneath on the knuckles top edge under the point in red but the hose doesn't move on the back side - the Caliper and hose connection stays in same position relative to the knuckle. 99.9% of the movement is on the front side when you steer. Might be a little movement as caliper floats while breaking but its negligible. The upgraded line doesn't swell during braking so less movement than OE. The line would probably be ok without clip but it is a good idea to try and protect any possible chafing being a brake line.
If you wanted you could hone that edge a little just to be extra prudent if your casting has any sharpness.
Let us know if you see something on your install you think might be an issue.
