Possum
If you have the dual thermostat, does that mean you might already have the high output water pump?
That is something I can understand. Now I know what needs to be done.So the history on the cooling system is early v belt models had a low volume water pump that was normal rotation. When they went to the serpentine belt system they still had a low volume water pump but it is reverse rotation. In 96 (depending on which manufacturing plant) they went to dual stats and a higher flow water pump, (all 6.5 serpentine we're reverse rotation) starting in 98 they went to spin on fan clutch. Most say to order one for a 99 to make sure you get a balanced flow pump.
If I remember right. They started offering “high output”water pumps in 97 but was the 4 stud water pump but it still didn’t come close to balancing the system. After that didn’t work like it should have. They come up with the 99 and 2000 balanced flow water pump.
I have already ordered everything. I am one of those impatient people that have to have it now. Lol@Possum I have some parts here, I'm not sure at the moment just what all is here, I will look this weekend and I may have something you can have cheap, I know I have a 9blade fan I'm not using and a good clutch, let me check this weekend, if you haven't ordered anything yet hold off till I check what I have...
Month? Try a couple of days, or even one drive through a cloud of bees when they're swarming. I drove through a swarm of bees crossing the highway while on my motorcycle up in Minnesota back in '82. It was neither enjoyable, pretty or neat!Yeah, where some of you guys live that screen idea could be golden. Here it takes a year to fill up condenser to what you guys could do in a month of springtime. I am thinking with my hummer of using the screen tried down like a blanket and mine would be hidden under the hood. Probably do my sons 01 dodge easy too.
And then there's the midges, flies, earwigs, june bugs, lady bugs, cicadas (BIG splats), wasps, hornets, bumble bees, katydids, praying mantises, crickets and lightning bugs I've cleaned out of the cooling fins of my stack. Bug screens are very acceptable out here on the Great Plains, much easier to take them off and clean than to take the stack apart and properly clean all the casualties out when she starts to run on the warm side.
