So besides having slightly different design, any reason you couldn't just use dodge wheels on the rear?
I've seen some dodge and ford that were pretty similar.
Sent from my SAMSUNG-SM-G890A using Tapatalk
That's a fair question. I went with all Ford wheels for a couple reasons:
1. The Ford wheels have a little more offset than the Dodge wheels, so if I choose to go with larger tires in the future, then I already have a little more space available in between the duals because of this. Of course the greater offset is what caused the wheel to collide with the drum, so there's that.....
2. The second reason, and really the more important reason, is that I only want to carry one spare wheel and tire on this thing. If I had the Dodge wheels on the back and the Ford wheels on the front I would have to carry 2 spares because I wouldn't be able to use one in both places due to the different hub sizes - a Dodge spare wheel wouldn't fit on the front of the truck because the axle hub is larger than the wheel and a Ford wheel would be loose on the rear axle hubs and wouldn't be concentric with the axle which would make it potentially go down the road in an egg shape. I suppose I could have carried a Ford wheel with a hub spacer that I could use or not use depending on where the spare was needed.......I hadn't thought of that before. But anyway, that's why I'm running Ford wheels all around.
Oh, I also could have had the front hubs on the axle turned down to the Dodge size, but the hubs are rare-ish (or at least somewhat expensive to replace) so I didn't think it made sense to permanently change a part like that just so I could run Dodge wheels all around. I wouldn't be surprised if some day the truck gets a 10.25 Sterling thrown back under it.
You're right though, the wheels visually aren't that much different and so if I had decided to put the Dodge wheels on the rear and Ford wheel son the front nobody would have ever known.
It would sure be nice if all 3 manufacturers had standardized on the same hub size - must be one of Will's gub'mint conspiracies!!
