Jaryd
Extremely Deplorable
Ok cool, I'll probably have to invest in one of those.View attachment 50370 since you have a vacuum pump and gauges then it would be worth investing in a micron gauge like this. Especially if you have to do a couple vehicles. Pull it down to 500 microns and you've got a real good dry vacuum. I paid about $100 at the local HVAC parts house the last time I bought one.
I used my wire loom installation tool for the first time and it made looming it a breeze!! That was how I ended the few hours I spent on Saturday.
Never seen that convulted tubing tool.
Might have to get one. I know a lot of the loom on our new suburban is gone.
Sent from my SAMSUNG-SM-G890A using Tapatalk
That looks a whole lot better than wearing a sore spot on a finger sliding it down the loom!
Yep, I used the rusty metal red oxide primer. I've used it before, but not in such volume or on such a highly visible application, so I'm hoping it holds up relatively well.Did you use the rusty metal primer? I really like it and use it alot. Seems to take awhile to harden up though.
I didn't realize that it wasn't the fish oil formula anymore.I've found that it scratches pretty easy but it seems to really help with rust. I don't think it's as good as the old fish oil formula but still pretty good
Yup, us in wetter areas of the country have this problem all the time. A primer/sealer will help with the problem and give you a little more time to leave it uncoated, but eventually those too allow rust.Something I recently learned a out primer... difference of a primer and paint is primers leave tons of microscopic holes through it, and layers like a honeycomb. The key desired point of primer is to bond the top layer paint through the primer and to the base material. That's how it bonds the paint better than not having primer.
Unfortunately I learned this because we would primer stuff, and the primer didn't seem to withstand the sun or something and wear out allowing rust to start. Turns out, the rust was starting almost right away underneath the primer and letting it grow through the primer. Since things don't rust quickly here this was a slow lesson learned before I did research to understand what was happening. So when primering anything know that you are. Ot really buying ny time before needing to paint. Oops.
I'm guessing most of you all in the rusty areas knew this, but just incase there is someone in a drier place than me-Idk- Death Valley maybe? haha
Oh, there was one complication: when I removed the hose from the low side port the shrader valve started leaking!! I hadn't leak-checked with the gauges removed. So I swapped that and luckily fast enough so all the refrigerant didn't leave the system, which would have forced me to vacuum all over again....so just a top off of refrigerant and it was good to go again.
On a positive note: all of the dash controls for the system work properly, so that's good.
