n8in8or
And 3 rolls of duct tape!Now, about 50lbs of Bondo to make the air dam and you'll be good to go!![]()
Don't forget the bailing wire, either!And 3 rolls of duct tape!
oooh, good call!Don't forget the bailing wire, either!
Backseat welder?That's what the armchair wingman is for!![]()
Hmmm, that's not a terrible idea.... I'll keep going down the path I'm on, but if I don't like the way it turns out I'll keep your idea in mind as an alternative. That would certainly reduce the amount of fab required.Here's an idea, Nate. Take a gasser front bumper, turn it upside down, notch it and box it to fit around the bottom of the radiator and bolt it to the diesel bumper using the holes for the factory plastic spoiler. It would be solid, the lines would reflect each other and you would have a unique, badass massive looking front bumper that would be aerodynamic.
D'oh!! Yes, JB Weld! Oh, and hot glue and sillycone!!!!Still think it would look better with a stock air dam even if you had to section it . Paint it flat black and I bet most people wouldn't give it a second look . Flows with the bumper and body lines because , well it's stock . You guys also left the JB Weld off the repair list .![]()
Good call. Yeah you're right, it would be pretty much impossible to slip the loop end of the strap over a hook now. I may have to make sure I'm carrying a special clevis with me to make sure it works when I need it to. That's the disadvantage to not using the stock deflector that is set back further.I'd want the holes a little wider, looks tight for anything but a slip hook
I like your idea of flat black. I think flat black would be a great color for the air deflector. Easy to touch up and possibly more durable from the extra texture. The contrast could be nice too.Still think it would look better with a stock air dam even if you had to section it . Paint it flat black and I bet most people wouldn't give it a second look . Flows with the bumper and body lines because , well it's stock . You guys also left the JB Weld off the repair list .![]()
And duct tape!D'oh!! Yes, JB Weld! Oh, and hot glue and sillycone!!!!
Nope, none of those fancy tools in my possession yet, so I have to do it the old hack-and-weld way. I don't think it will be too terrible, but the next couple days will tell. This weekend should be when a lot of that progress happens.The problem with the stock air dam is that it is plastic and offers NO impact protection to the bottom/sides of the radiator in case of something like hitting a 25lb male raccoon or catching a steep driveway entrance, Nate'll need more than just the welded flat framing around the bottom/sides of the radiator that's there now. Definitely build that air dam with the flat stock you're using, Nate. Do you have access to an English Wheel to bend the curve with instead of cut-and-weld, or perhaps a mandrel bender?
