I wished people would quit spreading this false info. The ONLY difference in the controls from the 4l80e's inception to the last ones used was the 91-93 used a pcs that required a cleaning cycle every 10 seconds, and 91-92(some early 93's) used a different plug that was prone to leaking, and many have been swapped out to the new style to help stop leaks. Aside from the pressure control solenoid(which is only an issue if you have one of the early pcs's still installed, or use a 91-93 factory controller. And the unique pcs can be swapped out for a 94+ style and be controlled by any 94+ style controller), they are all controlled identically. The only other 1 off thing was 91-93 4x4 4l80e's had an output speed sensor in them and 40 tooth reluctor installed because the early 1st gen ecm's weren't capable of doing the low gear conversion to keep the shoft points correct in low range.
It was the 4l60e that had all the control changes through the years.
