http://leroydiesel.com/products/bypass-restrictor-fitting-brf/
One more piece in the 6.5 cooling puzzle.
The factory quick connect has a biuilt in orifice in it to restrict flow to the heater cores. You want flow to them, but not too much flow. The orifice is needed to prevent excess pressure from blowing your heater core apart when a pressure spike occurs.So I've been thinking about doing this for quite awhile now, what's always holding me back is won't it limit the amount of flow the heater core gets? Max heat is as important to me as max cooling from your AC is for some of you guys.
So this is for the dual stat guys.Just to confirm this BRF is not the one on the Tstat housing going to heater core. The BRF go's on the water pump, see video.
