I know your fuel shut off is rigged
thats why I was asking.
Unplug it then.i'm thinking IP. might not be the one that was removed. i have another one i need to look at to determine.
here's what happens when i leave the frame mounted LP plugged in:
both lines are submerged. i removed them and cleaned it all up.....When you installed the tank, are both lines submerged? .........LP is loud...........What is the deal with the shut off solenoid.....valve cover, which since you already have the other off I say ok, hopefully a rocker button.....crack all 8 injector nuts listening for any variation. That will show anything like a valve stuck closed or individual injector/ cylinder issue...... compression test, which if your other valve cover removal reveals nothing is your next step........but same injector lines and injectors........
that will be looked at when i remove the VC.Sounded like mine when it broke a valve spring.
