So you and n8 had the same checking lifters and both of you had piston to valve issues . You have a different cam and he has a stocker , right ? Regrinds take material off the lobes and put a different profile on the " new " lobe . I lost .030 on the base circle and was worried that would need longer pushrods . Hydraulic lifters don't run up at the top of the clip , in the body , they kinda float in the housing . How many times have you adjusted hydraulic lifters , while the engine is running , and had to wait to do the 1 turn preload to not kill the engine ? That cam you have is not much bigger than a stock cam , can't see that being a problem . Now the ICL is a lot compared to my Crane @ 105 and I have more lift and duration than you . I didn't check anything , just primed it and crossed my fingers . Yeah , I know not the best way but it did turn over so I left it alone . Can you measure the base circle ? I have a stock cam and can check it .
