FellowTraveler
I suggest they last longer than standard rings - because you change rings due to blowby. I don't have any blowby. Of course you get any IDI rings hot and you ruin them. (Overheating takes the temper out of the rings and instant increase in blowby.) Further less soot in the oil = less abrasives and longer engine life.
Really hot days removing the radiator will run the transmission hotter and reduce AC performance. My trans shop plumbed in the air to oil cooler wrong and I suffered for years with high trans temps and poor AC performance. The AC condenser runs at 160 degrees on a hot day. Put a oil cooler that is 220 degrees in front of the condenser and you are heating the condenser up. I've blown off the emergency vent on the AC compressor several times due to this.
With both oil coolers going through the air to oil cooler first trans temps = 210. AC sucks.
Without the radiator in the loop trans temps = 220 and AC still sucks.
With the oil going through the radiator first and then the air to oil cooler trans temps = 180 and AC works in 121 degree weather. This is what I run now and thought I had all the time.
(AC has VOV orface for all configurations.)
Note: if you have an engine oil cooler in front of the condenser, well, the next step is it needs to be moved behind the condenser. You need air temps less than 160 degrees hitting the condenser or you are heating it up. Engine oil in the cooler is over 160 degrees... Yes head pressures are high at 160 degrees. I have not done this to my 1993 yet.
I'll be doing the total seal rings too. I'm at the point of figuring where to locate the aux coolers after I install a 2nd gen Dodge CAC/IC been thinking a HMMWV condenser as they are massive.
