The driven direction of the input shaft controls the direction it turns.
Jack shaft: Lets say you have a long shaft bolted to the timing gear long enough so other end terminates about the center of engine valley. Now turn IP so its input shaft faces the rear of the truck, mesh the two with a one to one gear and Voilà
Lot simpler said than done. You'll also need a sturdy bracket to hold IP inplace
