racer55
Member
The truck had saddle tanks installed but I had to add a sending unit and also an automatic transfer pump using the stock wiring.
The only sending unit I could get was a 100 ohm unit and now when the saddle tanks are empty the balance module tries to keep moving fuel from them and the rear LP keeps running.
Someday I will have to bend the float arm so that it maxes out @ 90 ohms and then I think the problem will be solved.
