Matt Bachand
Depends on the 6.5
Anyone with dual tanks having problems with fuel gauge or the automated balance flow system this may help.
This module is located by the front (main) lift pump. Slightly toward the rear of vehicle along the frame rail.
On top of this module is a fuel pump balance relay, it turns the rear pump on as needed to transfer fuel.
At the module, you have a harness with 6 wires. Unplug it and check the following with a digital volt/ohm meter
Terminal A- Pink wire, should be 12 volts with key in run position. Fuse is in underhood fuse/relay center marked IGN E 10 AMP
Terminal B- Light Blue wire, this is the signal wire from the secondary (rear) fuel tank, using an ohm meter, measure the resistance from a good chassis ground to this wire and should get a reading between 0 and 90 ohms, 0 is empty tank and 90 is full.
Terminal C- Dark Blue with White tracer wire, this is the signal wire from the primary (front) tank, test is same as for terminal B
Terminal D- Light Green wire, this wire controls the Fuel Pump Transfer Relay, with the ENGINE RUNNING and the front lift pump working, GROUND this wire, the Fuel Pump Transfer Relay should click and then you should be able to feel the rear pump working. If the relay clicked and pump is not working, connect a test light across the rear fuel pump harness connector and see if you have power. If lighted, then replace pump, if not lighted replace relay providing you have 12v at Terminal A.
Terminal E- Black with White tracer wire, This is the ground wire for the control module. Using a test light jump from Terminal A to Terminal E with key on, the test light should be lit.
Terminal F- Purple wire, this wire is the output signal to your fuel guage.
Gound this wire it should read empty, leave this wire open, the fuel guage will go pass full.
The fuel pump relay, which is right above the module, has a wiring harness with 4 wires. They are:
Pink Wire is 12 volt from the same source as Terminal A.
Light Green wire (thicker gage) is the feed to the rear fuel pump.
Light Green wire (thin gage) is the control wire from the module as explained in Terminal D.
Gray wire is 12V from the primary pump circuit to energize the Fuel Pump Transfer Relay.
