n8in8or
Thanks FT, that sounds right.
Says the guy whose optimizer ate a center cam bearing: "Put in new cam bearings while you are there, least you regret it later." I keep my old one in reach of the drivers seat in my rig as a reminder, no joke.
? Ah well, I'll have a set of Clevites put in and that should be that.Yep,The cam bearings are not very good in any 6.5 from beginning all the way through optimizer. (IDK about p400 cam bearings, Does anyone know what they run?) Your gonna laugh when you see the stamp mfr. on the back of the bearing when you pull it out...GM. When you do the rear cam seal do the red Loctite and really consider a safety screw. I think MissyGoodwench did a write up on that also.
