Chevypoor
Active Member
All your comments of rowing gears and feeling power roll through the truck/drive line is getting me anxious to get mine back in service.
My 93 would stall out anywhere below 2k w/ stock gm3 and turbo master pushing 12psi. Never felt power until 2400.
Yes I missed driving a stick. This is my first diesel stick I have owned and I love it. I have been surprised with T feeling so strong. I regularily shift when it is cold at 1600 or so and it will fall back to 1000 or so after the shift it pulls fine. No gearbox rattle either. Going through town I am in 5th at 1200 or so and she pulls fine. Regularly run through parking lots in 3rd with my foot off of the throttle and clutch and she is running about 10-12 mph and about 1000 on the tach. The ol timers used to talk about diesel equipment being weak, maybe some 6.5s were just not "broken in" right. I have had two pieces of identical equipment that felt and worked totally different! I test drove a 94 5spd that would not start out in any gear other than 1st or it would stall. It almost stalled a couple of times in 3rd going down the road! I have been meaning to try a trick I learned a few years ago on a cabover Pete with an old Detroit, probably 80's vintage. You could shift that truck through all ten gears (an Eaton 10spd) without touching the gas. On the high side in top gear if I remember correctly we were doing about 30-35 without using the fuel pedal! I think T may be able to pull off a run through the gears without using the gas pedal although the drop from 3rd to 4th is a bit steep.
