Lock and lube grease zerk coupler ?
schiker
Pendleton, SC
http://www.locknlube.com
There was a thread on tractor by net on this and many people liked it. So anyone here tried one? Looks like it would be good for equipment but not sure about the truck. It looks long and it's tight to do pitman arm.
Looks really handy but there's two problems. 1) If would be difficult to use it on some of the truck fittings because of room. 2) I'm way too cheap to spend that much money
Sent from my SCH-I535
No kidding, I think I didn't spend that much on my last grease gun, and it wasn't a cheapy by any means.
U-Joints come to mind for a genuine messy job that could use a lock. Everything else it is hard enough just to get the hose on the fitting let alone lock it on.
A lot of posts on the tractor forum griped about the cost. Some came back and said it was worth it. My loader has 2 zerks that are deeply recessed and have way too much grease squished out from not sealing. I sometimes don't get a good seal on lower ball joints and glob some grease out.
Greasing is no fun and I might try this coupler but yeah figure it's not going to fit some zerks. Being able to clip on and trigger the Lincoln on the tractor with out worry justifies the $.
umm, Buy a good grease gun tip and it has a crew adjustment on it that can tighten so much you cant get it on or off. I adjust mine loose for most locations, then when its a bad spot I just turn the foreword nut 1/2 turn and its not a problem.
I know a bunch have seen this but maybe not all...Something we always did on heavy equipment when possible is run a line to a more accessible place made from 1/8 hyd hose then put the zerk there. It was nice to grease 10-12 fittings from one location. Saved a lot of labor time. Thought about it on the hummer, but to much to get hung up on when offroading.
