turbonator
Member
I understood it to be mainly in the exhaust elbows but there is a difference in the two impellers upon closer inspection. Perhaps I could swap both the housings and impellers? Shafts are probably just different enough to prevent that though.
It would be really good info to take all the measurements of wheels and housings, to post up while you have the two tore down:thumbsup:.....it is not information that has been readily available. Maybe even a couple close up pics of the compressor and turbine wheels, that way, someone can estimate the trims from the pictures......we all know you are always looking for little side projects to occupy your free time....:hihi:
