I've been bouncing ideas around about doing stacks, I did them for shitz 'n gigs on my old 79 ford van back in the day, it had an old 460 I6 diesel non-turbo. The van had the step bumper, so I cut the holes for the stacks out of the step part at each end of bumper and ran the stacks straight up(covering taillights), all the way to roof then curved straight back. Now I had the ever-so-smart idea to run a straight pipe replacing the stock massive muffler.....BAD idea, resonation was VERY bad until you got to around 55mph+, it would give you an instant migraine when it reached 35mph unless you nearly floored it.
Now, for my 96, I'm sure I'll keep the stock muffler or an aftermarket of same quietness, I plan to use the steel-braid flex pipe, and here are my ideas for what to do. Just a heads up also, I'm not deviating from using straight cut tips with flappers.
Should I run single or dual stacks?
(If I run single, it won't be center-mounted, either driver/passenger.)
How far should I run the exit above the cab?
(The higher you go, the less noise in cab....but too high and it doesn't look right.)
Here are the sizes I'm stuck on choosing(mainly due to availability/cost of parts):
3"(same size as new downpipe, so no deviation in size from turbine to exit)
3.5"(bit bigger, parts cost same as below)
4"(anything bigger and prices of parts pretty much triple)
It's not that I don't make enough money to get kits and stuff, but it's funner for me NOT to be like the rest of the crowd.....and trust me when I say everyone around here has stacks. It's also fun to build/fab your own stuff. So what do you guys think should be done, given those parameters to play with? Also another idea, but I doubt it would look right, running the tubular muffler(s) as part of stack. That used to be seen on old logging trucks around here, I'm not sure how it'll affect the sound levels though.
