I just spent some time out at the pick-n-pulls today and pulled spindles from an 02 DMax for a brake upgrade like M.Kasperan did.
My question about whether the newer, larger MC would fit on the older hydroboost is answered, no it won't. The older MC has a nose, that fits into the hydro, of about 1 1/2" diameter ( didn't write down this info, having to trust my memory which is scary!!). The newer MC has a nose of about 1 13/16ths", so it's a substantial difference.
Sooo, in order to get the newer MC on the older trucks the newer hydro has to be installed along with the newer MC. BUT, there is a problem there also. The newer hydro has a different bolt pattern where it bolts to the firewall.
I went ahead and got a newer hydro and master so I could see what could be done to make them work in the older trucks.
I didn't have time to pull an older hydro to compare to the newer hydro, but after doing what I could to do some comparison measurements, I think there may be a work-around for that problem. I turned myself on my head and spent some time looking under the dash of an older and a newer truck.
The nose of the hydro that goes through the firewall appears to be the same between the older and newer style hydros. Both have removable mounting plates that have the mounting studs welded onto it. I'm thinking that the firewall mounting plates can be interchanged. Sometime later this week I'll spend some more time at a pick-n-pull and get an older style hydro so I can find out for sure if the newer hydro can be easily made to work in place of the older style hydro.
Don
