It's really wasn't that hard. You'll need a 10* reamer. The ball joint in the older trucks 88-2000 are bigger then the newer 2500HD trucks. I reamed the ball joint hole until the ball joint from my 98 fit in the spindle from the 2500hd to the same depth (top ball joint). The lower you have ream A little more to clear the axle. I used the outer tie rods from the 2500hd truck which are female. I bought two cheap outer tie rods for my 98, cut the ball joint end off the turned them down and retreaded them to fit the 2500hd outer tierod. So what you end up with is a threaded rod that fits the stock adjuster on one end and the 2500hd tierod on the other. After that it's a basic bolt together deal. Then get a front end alignment and it's done.
Thanks for the info. I do have more questions also.
Today I checked out the difference between the outer tie rod end for the 94 and the 2002. The 02 taper is larger by just a little bit. The 94 is 9/16ths in the cylindrical part above the taper, and 21/32nds for the 02.
The length of the taper appeared to be the same. The threaded end on the 94 is 7/16ths, and the 02 is 1/2".
Since the ball joints for the older trucks are larger you'd think the tie rod tapers would also be larger. But no, it's exactly opposite, the older tie rods are smaller tapers.
I have no access to, or experience with, a machine lathe. Because of this I'm wondering about a tapered spacer to allow the 94 tie rod end to fit into the 02 tapered socket on the 02 spindle.
A spacer like this is used when swapping/upgrading front drive axles and tie rods for the 60's, 70's and 80's Toyota FJ40, FJ55, FJ60, and FJ62.
I'm thinking the Toyota taper is different than the GM taper so I may have to do some searching for a spacer.
Somewhere I've read where I think a bronze starter bushing was reformed to make a spacer for the tie rod ends. I'll have to do some searching a iIh8mud (Toyota Landcruiser website) for more detailed info.
You state a 10* tapered reamer is used to slightly enlarge the holes for the ball joints. Is this something that can be done on a drill press, with proper jigs to hold the spindle? I'm a cabinetmaker, so I'm used to making wooden jigs for specialized applications.
Also, where would I find a reamer? I know where to find things for woodworking, but not for machining.
What did you do about the ABS system? My 94 has ABS, but since it is OBD1 I don't know if it would be compatible with the OBD2 of the newer system.
Don
Edit: After some time thinking about it I think I now understand what you did for the tie rods. Are the tie rod threads different size between the older and newer trucks?
If I can find someone with a machine lathe I'll go to the pick-n-pull and get some used tie rods, cut the taper joint off and throw it away, saving the shaft portion to make a threaded rod.
