guybb3
Member
I just got my hands on a 88894044. Anybody know what the deal is on this one? It was supposedly a take off from Peninsular since the marine engines use a different set up.
It looked to me like the threaded orifice was the only true difference. And it looks like Heath made it smaller, instead of the 1" or whatever size its only like 1/4". So then less goes to the drivers side, to balance the flow I suppose.
So for someone with a 2000 year system, is it worth it? I wouldnt think so, but if you have a 94 or 95 it would make more sense.
I don't think we have the difference nailed down on Heath's pump. The bypass being reduced to 1/4" would appear to not matter when the thermostat opens and blocks the bypass passage off - that bottom valve spring thingy on the t-stat should completely block the bypass off.
That reducer is for the dual thermostat trucks only. The dual stats don't have the ability to block the by-pass like the single stat does.
Are you sure, Burner? Because I thought that the Heath kit I saw WITH the restrictor was a single stat. I definitely could be wrong but that's what I'm remembering.
Check this out ( http://www.maxxtorque.com/dieselcommunity/spring-2009/65l-diesel-oil-cooler-upgrade ). Scroll down to the section on the water pump.
So now the question is which pumps have the balanced flow since I already have a single thermostat manifold? Is it every one with the screw on clutch?
They got the balance pretty well figured out with the 97 pumps. There's no advantage to the thread on pumps that I know of, unless they increased flow beyond 130gph.
It's not the flow but the even flow side to side. The first HO pumps were no better in this regard than the non-HO pumps. What year did the thread on pumps start? Another dumb question, would a 88894044 part # be a newer design than a 88894035 part #? Seems logical but??????
Did you test this, or are you just repeating something someone else said.
surely by now the new replacement 97 HO pumps are the same pump as the 99.5-00 pumps, just with a four bolt flange, no need to cast two different housings if one is inferior.
Big T, I hate to be a pain but can you get a straight down shot at those. I understand what you're saying but I have a hard time seeing it from the angle you have. I would definitely appreciate it.:smile5:
