cub124
Half Moon Detroit #1
Hey guys haven't been on here in awhile but I'm finally running 90%+ waste motor oil. I have noticed my egts have been higher (obviously) but lately I can barley go down the bypass without hitting 1100*F in 5th gear (nv4500) with 3.73's. I live in PA so there is some grades from work and back but nothing terrible.
Long story short here is all the details:
oil sits and 10% drained off then centrifuged for 1hr per 5 gal
filtered to 6 micron after centrifuge
dumped in truck tank sometimes cut with a few gallons of diesel fuel
truck has 6.5L lift pump pushes through a 12 then 2 micron then to the pump
injectors pop at about 2,400 psi
lift pump puts out 3 psi at idle 0 psi cruising
hx40 waste gate is wired shut tight and a spring is used to keep tension on it in the closed position (built 15psi in 4th gear on my way home egts ~900*F)
I'm not sure if the IP is starving causing bad atomization which is causing high egts, if I have a dripping injector or if my injectors are just dirty.
EGTs at idle are normal about 400*F
Hopefully warwagon or someone with lots of WMO experience can give me some advice. I'll try running just #2 diesel tomorrow to see if it helps.
injectors are less than a year old and have less than 10k on them
trucks power seems normal maybe a little low in 5th
