Dw89xj
Okay I'm swapping a 6.2 in place of my 350 in an 87 suburban. My plan is to use the 6.5 lift pump in place of the stock TBI fuel filter. Knock out the restrictor in the filler neck. Manual glow plugs. Regular fuel filter setup like on equipment. Install the diesel rad and call it macaroni. Is it this simple? Will the gas supply line be enough volume for the IP? What about the factory return, can I just block it and be done? Or do I need get the actual diesel pickup? I'm getting the whole drive line engine to transfer case, its a th400. I'm also getting the hydro boost setup. So is my thinking that other than basic Chevy swapping, will bit be as easy as I'm thinking or is there something more difficult I'm not seeing or overlooking? Thanks for any help. It seems almost too simple.
