Upgrading To A Larger CS144 Alternator.
bowtiebutler956
Active Member
Harlingen, Texas
The alternator went out on my 93 K2500, which didn't surprise me, as it was an inexpensive CS130 I got on ebay that was supposed to be upgraded to a 160 amp unit.
Well it didn't actually quit charging. Something was draining my batteries overnight, and I traced it to a 4 amp draw from my alternator, which meant it had a bad diode. I'd never been very happy with this alternator because when I was idling with the A/C on, headlights, stereo, etc.. it would drop to about 13v, and as soon as the rpm's came up, it would go back to about 14v.
I decided to spend an extra $20, and upgrade to a CS144, which is a larger alternator, and the one I got is rated at 140 amp, as opposed the stock CS130 being rated at 105 amp. Here is the Orielly listing for my new alternator. Ultima 8219-5B - Alternator | O'Reilly Auto Parts
The real difference with the bigger alternator, is its charging power at idle. This alternator stays at 14v or above, even with the A/C, headlights, stereo, running while idling in drive.
It was almost a direct swap. I had to make an upper bracket to replace the factory angled one, because the upper ear on the CS144 is much wider, and more robust. A piece of 1" wide strap worked perfectly after drilling a couple holes in it. I also had to purchase one 3/8"x3" long bolt, to use on the alternator. I had to get a slightly longer belt as well. I used a 6K1015 in place of my original 6K1005. I'm aware that most the factory alternators use an extra support bracket on the back of them, but mine was missing when I got my truck, and I never had a problem. It should be stronger than before, as the larger alternator has a much stronger upper mounting ear than the one it replaced. The plug for the CS144 is the same one used on the CS130, so everything plugged in, and worked perfectly. I had already upgraded the charge wire going to the alternator to a 4ga. wire, so that was already good to go. I took pics to show the differences in the alternators, as well as the new upper bracket. I think this swap should be the same for trucks up to 95
, or the ones that have the alternator on the drivers side. Thanks
Matt
Leroy had his cs144 snap clean in half without the rear support. I recommend you make a rear bracket of some sort for it esp. because the larger alt is fighting the engine vibration more due to it's greater rotor inertia. I have busted the flipped over front support so your new part is a plus there. Diesels are extremely hard on alternator brackets and even the factory brackets do break.
Thanks for the heads up WarWagon, and I'll get to designing a rear support.
I made a bracket from round tube to go from back of alt to the intake.
You had one break in half Leroy?! Got any pics, and maybe one of your support bracket? Thanks
Matt
I have a bracket. $20 + the ride in a Med flat rate $15.
I don't have pictures this happend before I had a camera.
Here is a couple pics of the bracket Leroy Diesel will sell with some serious arm twisting. I wish he would offer this unique needed item on his site... As well as a flat bar for the front mount that is stronger than the factory one flipped around...
Thanks for the pics WarWagon. I like that.:)
Its red too! perfect for Matt.
Well, generally I'm a diehard do it yourselfer, but being that its such a nice color already, I'm sold.:D I'll send you a PM shortly Leroy.
Matt
I would not be surprised if everybody gets their stuff before Xmas. I got stuff today, that I ordered Saturday, and I didn't overnight it. The PMD cable from Leroy showed up in 2 days as well.
