I had several friends all flushed out dot3 for dot5 some years back. I was dd my hummer which ran dot5 factory.
They all had to replace all rubber components by time it was done and they went back to dot3. The two aren’t compatible basically.
This leads me back to the question I had for them: why? If you are road racing or towing so heavy that you are overheating your brake fluid- you might focus on why it is getting that hot. The military chose dot 5 because when water gets in the system, it separates from the fluid and is easily purged. So AM General stayed with it until they added abs and couldn’t use it. The brakes on hummers came off AMC Eagle 4wd wagon. Even the 1.9:1 ratio of geared hubs isnt enough to offset the weight difference So yeah, hummer brakes are crappy. But until an abs hummer turns his rotors blue, the fluid is still not overheating.
The molecular composition of fully synthetic brake fluid is easier to generate leaks with- proven by the synthetic engine oil and transmission fluid leaks started which they later changed the seals and sealant for. The synthetic fluid isn’t going to increase braking power. It might extend sealmlife if the seals are the right type, or dramatically shorten them if wrong type. So to me thats a coin flip gamble. The biggest problem long term with any brake fluid other than dot5 is moisture. Just flush in new fluid every few years a d be done imo. I don’t understand how the change in fluid is advantageous. Keep in mind a worked for oil and fuel companies that dealt with both conventional and synthetics- so much if the hype goes no where on me. Metal to metal friction is where synthetic oils and fuels help. And since there is none of that in a brake fluid system...
