Woody35
Active Member
What are your thought about adding a second stock lift pump inline with the other one already there. My uncle works at the parts store so i can get them pretty cheap. I already got the FTB
should i wire it up to the ignition relay or lp relay
With your parallel feed, did you need check valves so that when only 1 pump is on it doesn't feed back to the tank? Or does the pump itself act as a check valve?
