I found it at "the auction site". Search for "180273186146"
This major turbocharger rebuild kit includes:
2 Journal bearings
3 journal bearing snap rings
1 Thrust bearing
2 thrust collars
2 Compressor side seal rings
1 Turbine side piston ring
1 shaft nut
4 Seal plate bolts with washers
1 beaded flange gasket (not shown)
1 Oil drain gasket (Not shown)
Is the "thrust bearing" another name for the "thrust washer" you spoke about?
It was $86 incl shipping and balancing if I...
"ship me the parts I need and return shipping, I will clean, inspect, polish, balance & ship back to you in the same day. I strongly recommend you have the assembly balanced for durability, all you pay for is the shipping. I don't need the complete turbo to balance. I need the compressor wheel, turbine wheel, thrust collar, spacer and shaft nut"
Any torque values avail so I don't over tighten (as you warned against)?
Should I not be doing this?
