1994ch
The other day I swapped out the radiator and had trouble getting the transmission cooler line fittings to fit in the new radiator. So since I was at the shop and had to get home.... and its the only vehicle I have, I just by passed the radiator and so it is running on just the external cooler up front.
So my question is how big of a priority should I make of getting back in there and finding some fittings that will work? I have heard that the main thing the radiator cooler does is actually warm the trans fluid up to operating temp faster. Is this true?
I assume I am fine running short hops to and from work but if I went for a longer trip through the mountains does the radiator cooler do much to keep the temps down?
Thanks for any input,
