racedaymechanic
The last trip to the mountains My 4L80E was running a little hotter than I like, I have been wanting to get rid of the OEM rubber lines for some time so It was time to fix it up, Building the mount was quite time consuming and took alot of fitting, welding and Head scratching so I didnt document it ( alot of Beer and swearing) I used Aeroquip high pressure hose and fittings, they are bulletproof, I used a 10 inch electric fan (leftover Nascar stuff) I replaced the OEM Trans cooler with a B&M one with 1/2 inch NPT outlets then used Aeroquip fittings to go to an6 then added a old engine cooler I had in line the fan is on this cooler
Heres how I tied into the existing Steel 3/8 line Nut, sleeve then flare 37 degree 6an x 6an union
This is the fitting that goes from the bottom of the Rad to Hose
This gives you an idea of the fab work I did, the fan is on the backside not visible, I mounted it where to old skidplate used to be
Heres the mount I made for my engine cooler lines
I installed a switch on the dash with a light so I can know when the fan is on
