That "quick disconnect" on the thermostat housing
Murph
Mohegan Lake, NY
Is where the coolant leak is. Looks to me like 1" pipe thread going into the t-stat housing. Is that correct? Anything wrong with replacing it with a 3/4 hose barb-NPT adapter and running new hose to the rear seat heat T?
Andy
It's actually 1/2" pipe thread, and yes it can be replaced with a regular fitting. The problem is though it is supposed to have a restrictor inside of it to prevent overheating and overpressurizing the heater core. It should have roughly a 3/8" hole inside the fitting for a restrictor. You can purchase a fitting for a H1 HUMMER and it will have the correct size restrictor inside of it and use a 3/4" hose barb connection on it.
Thanks Ferm...The Chevy dealers around here are sorely lacking in 6.5 parts, but the Ace hardware has a good brass section, so I'm improvising ):h And I'm a cheap bastid too.
Andy
There is a steel replacement fitting if you want to replace it with OEM style, found in auto part stores in HELP products section.
That said I've been running a pipe thread/barb fitting for over 4 years on the truck; and 2 years on the Burb without negative impact.
Napa part number:660-1732 . I just snapped one off yesterday and am replacing it with the hoe nipple like the 6.2s have. What kind of a idiot would design a fitting like the quick connect that has NO rubber seal. Now to get the broken off piece out of the crossover. Napa told me they make a special tool to remove the broken piece. Too cheap at this point to buy one.
Should some type of heat sheilding be used on the heater hose or will it survive the turbo heat?
Is the hose 5/8, or 3/4? I thought it was 3/4...
Andy
Take out the hose from the quick connect. Which it looks like you did.
Use a socket (not box wrench) and breaker bar and rotate it slowly.
You should be good to go after that if it is not breaking.
Replace it with that one suggested above. The hose has to fit the outer diameter of the metal portion of your old one.
It actually DOES have a little flat type O-ring in it - on my truck, when it
started leaking, I was lucky and able to unscrew it - I replaced it with the
same thing, gave me 180,000 miles before it leaked the first time, I'm
satisfied with that. :smile5:
But on my sons' Firebird, it broke off, and I couldn't get the piece out for
anything - ended up having to drill it out and retap it with a 3/4" NPT tap,
just used brass fittings from Home Depot on his.
EDIT: maybe it was 1/2", I did it a couple of years ago, don't remember for sure
Looks can be deceiving :D In the pic my hand was blocking the hose from view, it's still connected. I just got back from the parts store with the NPT-hose fitting above, some 5/8 hose and a gallon of Dex Cool. I'll be working on it later when everyone else here goes to sleep.
edit - why a socket not a wrench? It has more surface area in contact with the fitting so not to crush it??
Andy
Andy
A socket will give you more of a rotating motion, the wrench can
apply sideways force and have more of a chance to break it off,
these things are brittle when they age
Exactly!!! There were people using wrench and they broke it off. Not me though, I learned it from those who are a little unfortunate.
In other words, the wrench can apply uneven forces to different direction.
Hmmm... The one I bought is NAPA 660-1700, with the same size (by eyeball) restrictor as what's in the original fitting. It screws into the housing fine, but I haven't hooked it up to a hose yet.
The 660-1732 is 1/2" npt to 5/8 hose with restricted opening. Napa's quick connects were the same crap pot metal as oe.
Wow...Imagine that...
The QC fitting snapped...Flush...:mad2: What are the odds that someone named Murphy would run into some bad luck?? :errr:
I'm thinking a pipe nipple remover might work...
I wonder how much the stealer wants for a new housing?
Andy
Unfortunately, Murph, that's pretty common. We took out a friend of mine's after he snapped it off (flush, like yours) by using a cut-down hacksaw blade and cutting some channels into the nipple, right to the threads, then chasing the part out with a cold chisel.
PITA, but it came out.
Lisle makes the correct tool for it LIS62200
Ordered mine throught Advance Autoparts about $10
Here's one on e-prey http://cgi.ebay.com/ebaymotors/ws/e...156&sspagename=ADME:B:EOIBSAA:US:31&viewitem=
I saw Matuva post that one a couple of posts up, but I'm afraid of tapping it in what's left of the fitting, only to drive bits of the schitty pot metal into the cooling system.
I think I'll check the parts stores near me for the Lisle tool anyway ):h
edit - one good thing did come out of this...I found the DVM that's been "missing" in my garage for the past month or two.
Andy
