There is a lot to consider when talking about a "balanced engine", sure the rotating weight needs to be very close, but cylinder pressures need to be balanced as well. If the stock lifters leak down at different pressures in psi from springs, the lift will be different for any given cylinder as well. Sure other things like injectors, what shape the IP is in, static IP timing along with IP advance, stamped rockers, uneven pushrod length, and so on..
The bean counters cut a lot of corners, so sad...
Is their a perfect motor, well I can think of a few that may be close, all I'm doing is making every effort with this build, I said a few years ago my plan was to do all I knew about to bring my past into the p400, we will see how it turns out...
