Hiya everyone!! This is my first 6.5, but, i have owned 2 6.2s(that i loved) and i really do love my truck.
About my truck:
1995 chevy 3500 4 door dually
Choo choo conversion(ugly paint job, lowered, full ground effects, real ram air hood, and epic alum wheels)
6.5 diesel
4L80e trans
4:56 rear(thpught 4:10 at first until i checked it out completely)
While i love my potato(slow, fat, ugly), i am having a few issues.
I replaced the whole fuel filter assembly(new ac delco)
PMD relocated/replaced
New custom(i built) + battery cables(2g)
New ground wires
2 new batteries
LP and GP are on toggles(ops and gp relay bypassed)
Manual waste gate
Vaccum pump removed
IP replaced right before i got the truck from org owner(truck had 118k and now has 123k)
I am throwing codes for the first time in the almost year i have had it. I know what the codes are, i just dont understand why they suddenly showed up(i did jave a pretty major fuel leak filling the valley because of the fuel filter assembly) and my ac compressor(new) shredding half the belt because the clutch froze up(replaced the belt, ac compressor, and tension pulley). The service engine light came on(cruise kicked off) and i pulled over imed. and shut off the ac. Saw the belt half shredded, drove home(1/2 mile), replaced the belt, tension pulley, ac compressor and still had codes. Relocated the pmd, fixed my fuel leak, replaced or cleaned all grounds, replaced the + cables with 2g, and i still have codes. Side note: the truck runs amazing now once it decides to start(new issue as well that showed up with the codes). Fuel pressure, oil pressure, and temp are all good. I do run 2 stroke in the fuel for added lube since they decided to take it all out of the fuel with their bs ultra low sulfur(truck rattles horribly without the 2 stroke, is super quiet and smooth with it. I only add about 6 ounces per full tank and i use penzoil marine because she likes it better...lol)
Im kinda stuck because the codes make no sense(since quiet a few are for bypassed systems and never showed up before).
Thanks in advance for any help!!
About my truck:
6.5 diesel
4L80e trans
New ground wires
2 new batteries
Manual waste gate
Vaccum pump removed
