Thanx Frankenburban: Well...it's running! Here's the story for your information: I checked several YouTube videos and got several ideas. First, I had snipped that green/white wire but it STILL wouldn't start. Of course not! As you said, it's the Park Lock but I didn't tumble at that time. Next, I copied several "re-learn the passkey code" techniques. One said to do the 10-minute wait thing ONCE and another said to do it 3 consecutive times. Remember, my truck is a 2000 K3500, and from what I've seen in videos, it has the earlier (more primitive) anti-theft system. It does have a "Security" light, but just the word "Security" that comes on in the upper-right-hand-corner of the instrument cluster.
Thirdly, I read a guy who said the instrument cluster can be the problem. Something about electronic "noise" keeping the "re-learning" process from occurring (because I did install a new key and tumbler) Now, my plastic screen cover is cracked and I'm going to have to replace it anyway so no problem removing it. And lastly, I saw the video showing how to splice together the yellow wire with the orange/black wire to disable the whole passkey system altogether. (the three wires that plug into the top of the key tumbler)
And here's where I violated the "scientific method" by changing more than one thing at a time so I can't really pinpoint which "fix" worked. When I went back out I tried to execute the "re-learn" process. I did it for one ten-minute sequence and it didn't work. By now the batteries are going dead from all the fiddling around. (I just bought these batteries)
I put the batteries on charge and removed the instrument cluster (which I was going to have to do anyway) The guy said the truck will run without an instrument cluster. I unplugged the clip to splice the passkey wires but stopped. Let me see what happens when the batteries are hot again. I plugged the passkey wires back-in. I reconnected the batteries and turned the key and VAROOM! My bad-boy started right up! But I can't really be sure what did it. Did it re-learn from an earlier try or was the instrument cluster the problem?
It does come out of PARK without touching the brake pedal, (but that's because I cut the green wire) but another change I made was that I pushed the emergency brake in slightly so my headlights would go out and not run down the batteries anymore. I don't know if THAT means anything, but I wanted to mention it. I'm going to make sure it's back to normal, by driving it around for a while, but before I put it all back together, I think I'll splice those wires and disable the Passkey System altogether.
Thanx to all for your patience and help.
