- Staff
- #1
I am rebuilding my 1995 Lance 990 Extended Cab.
I am using this thread to track what I tear down, rebuild, and how I do it. This camper has extensive rot on the left and right wings(the part on the back that hangs below the body line). The entire back below the rear lights. The curb side from the front all the way back is also rotted and falling apart. I am sure there is more that I will find and have to fix. I will inform myself and everybody that reads this the details as I go along.
Here is the beginning and what I have done so far from when I purchased it.
http://www.thetruckstop.us/forum/showthread.php?37947-1995-Lance-990-Extended-Cab
Here is the start of my tear down.
I already took the rear jack off. Here is the lower mount, you can see it is way down.
I had to pull the ladder to get the lower siding off.
I removed the two siding end caps.
Here is the gap I am having with the rear bumper. There was really nothing holding it on.
I had to pull door screws off to get the siding off.
Here is a picture with the lowest back curb side siding off.
More to follow.
More to follow.
