Acesneights1
I'm at -1.50. I can't tell ya how i got there. Just got lucky.
Why are we talking bumping and TDCO adjustments in the same paragraph, NVW?
Also, as I recall, TDG is even now somewhere up there in the Great White North, bumping his heart out.............
Just for the uninformed you won't find TDG in the acronym file.
TDG=Texas Diesel Guy from the old site.
Did not even consider the OS Bump, because I had determined the consequences that would result with a mod that affected operation over the entire rpm range,
Over-sensitive, squirrely APP, incorrect timing parameters, fuel distributor position @ stock +3.5*BTDC incorrect for OS 'bumped' position @ +5* over stock
problem was, noone could explain it evenly remotely satisfactorily
No, my friends, I didn't invent it - my travails were in finding a viable explanation in an explanationless world - TDG's explanation of the OS Bump, which was also being done successfully, finally closed that door
I`m not sure about all this timing stuff. I`m just reading and giving You a bump back to the top so maybe someone with more knowledge than I can reply.In GMTDScan Tech, my actual and desired read around 11* with the truck idling. TDCO reads an even 0*. I haven't tried to command timeset or TDCO. Are these ok numbers to start out with?
