Problem: Heavy shudder upon braking
The vibration did not exist when the drums were initially installed. Belief is that the one locking up caused it to overheat and warp. The vibration started recently, like just before the tie rod broke which had me focused on the front.
I would still see if I could find a place that turns drums.
I've heard a lot of stories about new,bad drums and rotors.
I don't know if cheap aftermarket rotors have improved, I haven't heard any stories about them in quite a few years.
But then, nobody checks them anymore.
The last bad drums I heard of, were a few years ago.
If you find somebody to spin them, I doubt they'll charge much. Especially if they spin true.
Is there a way to put them on a hub and hand spin them, just to check. Before installing?
If they're Chinese I'd definitely check them.
When we spoke on the phone, you were sure it was front axle chattering.
If not sure, get a line plug and seal the line for the rears. Test. Then swap plug to front and test. Doing this you will be eliminating the plugged axle from braking so keep speeds minimal.
Everything is Chinese these days. I did not have problems when they were originally installed, other than the left rear locking up which was due to my install error on the right rear. If this drum is out of round, I will take it back to Napa. I bought from Napa for this reason as they have a 12 month warranty and I did not incur the exhorbitant shipping cost of retail online, let alone return shipping on me.
You'll never know if they're true, unless you spin them. I prefer to do it before installing.
That sounds good.
Let us know how they spin.
I will first try the new drum as is. If it does not cure the problem, then I will order a second drum for the other side. If that does not cure the problem, I will have them turned.
Realize that my installation error caused the overheat problem and resultant warping. It was never there from the manufacturer. This developed over time.
To me. The $20 once and done is worth it.
Was the first drum exchanged?
Did you check to see if it could be turned?
Sometimes things aren't right, but they aren't bad enough to cause an immediate issue.
Kind of like having a new injector that's dripping a little. It's not right, but it may not be noticeable
I sense that you are fixated on this. To me it is not hard to pull a drum.
I kept the first drum. Since it presumably warped due to overheat, I was not sure about turning it. With rotors, I never turn them because the “warped” area is from an increase in hardness of the metal due to heat. You can turn it down, but it returns because the wear in the affected area is less. I am assuming this also pertains to warped drums, but I still have the original.
To me, these days, I can't pull a drum or do much of anything else.
There never was a time, when I had time, to do things twice, if it could be avoided.
Things like testing injectors and stuff before installing, to have a better chance of never having to touch it again.
Back then I was working a lot of 7 day weeks. Anywhere from 8 to 26 hours a day. Keeping up with all of the vehicles was impossible.
I’m having two sets of Bosch India injectors tested by Bill Heath. He will pull apart at least one to inspect for CKO indicators.
As for the brake drums, I will know fairly quickly if the new one cured the issue. I have an incremental plan of attack for this issue and I’m working to it.
You are 100% correct when a rotor or a drum gets warped from heat-
IT IS NOT FIXABLE- REPLACE ONLY. You can’t turn them to eliminate it.
This is the opposite effect of chryogenic treatment. You overheated it then altered the temper by letting it air cool.
Good to hear it is finally sorted out. Nice to have new stuff out of the box not need adjusting or turning as you thought. Personally, I’ve never been burned so never thought I needed new drums turned and only ever had one set of rotors that required ‘running in.’
‘There is a season, turn turn turn…’ or not. So far, not my season. Now watch what happens with my next brake job….
It was never an issue of the drums being out of round out of the box. My error on the brake shoe install on the right side lead to the left side locking up and the right side only having the rear shoe applying brake force. This resulted in overheating the drums causing “warping” which is really hardened spots that wear less than the surrounding metal, thus the wop, wop, wop./ It is rare for this to happen to rear brakes because the front brakes typically account for 80% of the braking.
Anyway, lesson learned and it is back to normal. All of the new tires are on the truck now. Next up is to replace the thermostats.
The truck was running incredibly smooth with no shudder while braking.
It was my birthday and after splitting a bunch of wood, I decided to float and fish the river. I launched at Bell’s Crossing with my takeout at Stevensville Crossing. My wife shuttled the Suburban to the takeout at Stevensville. The whole time the truck was incredibly smooth while braking.
When I drive the truck from the takeout at Stevensville, the shudder upon braking was back. When I arrive home, my wife walks out to meet me and says “I screwed up. I drove it with the parking brake on.” It’s standard practice to set the parking brake when you are launching a boat. We were supposed to go to dinner to celebrate our birthdays. Instead, I’m drink bourbon and eating Ritz
crackers.
Tell me this is a late April fools joke…
Or maybe have April change the drums this time?
Nope, this is real. My hands are beat up and the next two weeks are long hours on the day job. Replacing drums is easy. Replacing brake shoes takes some time. I’ll try to get it done in the evenings.
