Problem: Heavy shudder upon braking
The vibration did not exist when the drums were initially installed. Belief is that the one locking up caused it to overheat and warp. The vibration started recently, like just before the tie rod broke which had me focused on the front.
I would still see if I could find a place that turns drums.
I've heard a lot of stories about new,bad drums and rotors.
I don't know if cheap aftermarket rotors have improved, I haven't heard any stories about them in quite a few years.
But then, nobody checks them anymore.
The last bad drums I heard of, were a few years ago.
If you find somebody to spin them, I doubt they'll charge much. Especially if they spin true.
Is there a way to put them on a hub and hand spin them, just to check. Before installing?
If they're Chinese I'd definitely check them.
When we spoke on the phone, you were sure it was front axle chattering.
If not sure, get a line plug and seal the line for the rears. Test. Then swap plug to front and test. Doing this you will be eliminating the plugged axle from braking so keep speeds minimal.
Everything is Chinese these days. I did not have problems when they were originally installed, other than the left rear locking up which was due to my install error on the right rear. If this drum is out of round, I will take it back to Napa. I bought from Napa for this reason as they have a 12 month warranty and I did not incur the exhorbitant shipping cost of retail online, let alone return shipping on me.
