schiker
My transmission input bearing wore out and clutch burnt up I think.
The story.....
I was going down the interstate running 70 mph and I heard a squeal develop. I couldn't feel it in the stick started to slow and tried to push the clutch pedal in and it was mushy and went to the floor. Pulled onto shoulder and the clutch started slipping and squealing louder smoke coming up from cowl and it starts to choke it down but slipping too. I stop and the engine stalls transmission in 5th as the clutch won't release. Gray smoke steams from the cowl. Engine oil pressure and temp ok. I put the transfer case in neutral and the engine cranked up fine.
I have the transmission out and the input shaft feels real wobbly and the pilot bushing is approximately 1/8 inch bigger diameter than original. The clutch disc is not down to the rivets and has some wear groove indicators still visible but think it went all wobbly and smoked the disc & pressure plate from thermal overload??? It has been shifting fine but a bit harder to get into 2nd gear at a stop light just lately. Spin down has been fine going into reverse. I'll probably take it to a local shop to rebuild and probably at minimum need input bearing, input shaft, and synchro's.
So now I have to decide what clutch and pilot bearing to reassemble with. I think I want to use a RAM clutch. They are headquartered 2 hrs away near where I grew up in Columbia, SC and hear from a close mechanic they are really good. Home town is a big plus and worth some extra money IF the product is good. Other options are ZOOM and LUK Gold maybe. I redid the clutch 100K miles ago and it was a Luk Gold. The center section looks ok not broken but the springs are worn some more than I think they should be maybe???? The original owner had a clutch job under warranty at dealer due to input bearing failure is what he said at 60K miles. I did a clutch job at 120K miles due to center hub of clutch disc failure.
What about pilot bearing / bushing???? I don't think I like the needle bearing style so its either a Oilite /bronze bushing or Kevlar. What have ya'll heard about the Kevlar life and performance. I am a bit disappointed the bronze bushing was wollered out significantly.
Opinions, stories, and feedback wanted about clutch brands and pilot bearing.
The story.....
