Finally got the engine out and the heads off. #1 is scuffed badly with aluminum welded to the top of the bore. The other 8 are fine.
Both heads have a crack between the valves on #7 and #8 holes.
How does the fire pattern look on the other cylinders? Wondering if this was an engine oil failure, too hot, bad injector, or too much fuel and boost?
Injection shop says the injectors are fine.
