Update
Finally put the events together and have the will to post it.
I scuffed and cracked a 6.5 piston over using an old fan clutch. Yup, got hot and then a defective radiator cap, new one, let go suddenly and shock cooled the block. The hoses were collapsed after cool down that evening. So the cap would not release at the proper pressure or let coolant back in.
Per Bill Heath cooling research: water flow is to the #1 cyl first and greater flow to that side. This sudden radiator cap release combined with high temps from a OEM worn out fan clutch and ineffective 6 blade fan caused the #1 cyl to shrink the most with a hot piston and hot thin oil. This chain of events scuffed the piston/rings severely and cracked it. The next oil sample said overheated oil and fix the egr due to soot. Fix egr due to soot the next samples - no EGR on that engine... and TM turned up the boost so there was no exaust smoke. So soot was from cracked and scuffed piston/rings.
The new fan clutch was on the way and replaced the next day. :nonod: I already had a HO water pump, new radiator, 180 T-stat, and new condenser installed.
I got another 7000 hard towing miles out of the engine before the crack burned through and required the engine to be replaced. It was burning 1 quart every 500 miles of oil as well. The engine was a zero blowby engine when I got it and had idle blowby after that day and high oil consumption till it failed.
1st thing you need to do when you buy a 6.5 is get rid of the 6 blade fan and test or replace the fan clutch. If the clutch has crud on the spring or is over 5 years old - $94.00 for a new clutch is cheaper than $1200 (used military 6.2 w/ 30 day warranty.) on up for a used/new 6.2/6.5 engine.
