Twisted Steel Performance
Going over the stock 1.5 ratio has proven to cause valve contact, P400 valve rescission is about 1/2 that of GM - GEP.. I don't remember what ratio you went with...
Crank the motor now and hold a piece of paper close to the intake runners, if the paper gets blown away from the port the compression is being pushed past a valve for what ever reason..
Did you check valve - piston clearance with putty when you put the motor together?
