Chevypoor
Active Member
This will probably get moved but here goes. Looking at buying a 7200gvw 6 lug 2500 2 wd 1995 reg cab truck. 139k on the odo. Nice clean 1 owner truck. Only issue is the 4l80e sometimes when you start it will not shift. If you shut the truck off and restart it will shift fine. Does not drop out of gear or stop shifting after this initial issue. The issue is only on startup. Or this what I have been told, have not test driven. Sound like a simple fix?
The truck is 5hrs away so before I drive up I thought ask you guys opinions, thoughts.
