coxpn2
coxpn2
I've been a member over at DP for awhile now, and have heard rumblings about how this site has more activity due to some changes made over there. No idea whether that is true or not, but I've been reading up on old posts over here for the last week or so and it looks like everyone is pretty helpful over here.
So anyway, here is what I've got going on:
-Bought suburban with blown engine, also bought donor truck with running engine.
-Took engine from truck and put into suburban, maybe 2k ago.
-Experienced loss of coolant, quite frequently had to fill coolant reservoir. (didn't appear to be going into crankcase - oil level didn't change).
-One night it started smoking white, decided to let it sit for a week.
-Ran it again, once warmed up it started smoking white again - ran for maybe 10 minutes while smoking.
-Tried to start it the next day to get it up to my parents barn - won't crank at all, needed to tow it up there.
-Tore down the engine in the truck (drained coolant only from the radiator drain, heater hoses, and top hose to thermostat).
-Pulled heads off in truck, coolant splashes all over when heads come off.
-Looks like head gasket is shot on passenger side front-most cylinder, possibly also drivers side rear-most cylinder.
-Get sick of working in the cold in the truck, so I decide to pull the engine out.
-Drain oil, and get a bunch of coolant out of the oil pan before oil starts draining out.
How would that much coolant get into the crankcase? All cylinders appear (from what I've seen) to be ok - no cracks. I haven't done an exhaustive examination - rotate so each piston is at lowest point and examine cylinder, but I'm hoping to get some clarity before I go back up there to work on it. I know if water is getting into the combustion chamber it'll force its way past the piston into the crankcase, but how much water could realistically go past the piston in 10 minutes of running without taking out the block wall?
I'm hoping for any insight before I go back up there this afternoon, so any help would be appreciated.
Thanks in advance
Thanks in advance
