To eliminate backtracking in the thread I'm going to restate the problem and what has been done to date.
250 miles into a trip shut the truck off for about 5 minutes. Truck immediately restarted and ran for about 30 seconds before it cut off and would not restart.
2. Year of truck/engine.
95 6.5 NON-TURBO
3. Odometer reading (indicate miles or kilometers).
~175000
4. Indicate the model number on the Injection pump (starts DS4 or DB2......).
DS4
5. Indicate if you know if it’s a 1500, 2500, 2500HD, 3500, 3500HD.
1500
6. Do you have an EGR on the engine? (An F or an S engine code 8th VIN digit)
EGR removed by PO. vacuum switch connected w/o vacuum other switches removed and wires jumpered. Had to
clear numerous EGR codes.
7. Air Filter condition (visual check).
good
8. Fuel filter condition (freshly changed, mileage since changed).
good unknown mileage but getting good fuel pressure and flow through it.
9. Location of
PMD/FSD? (ex. on pump/remote over intake, behind bumper).
behind bumper
9a. If remote mounted, describe wiring harness (homemade or purchased from which vendor).
looks purchased
9b. Indicate the location and condition of the FSD/IP grounding wire.
good condition on IP
10. Outside Temperature (C or F). _____ °
low to mid 40s F when occurred have tried starting when in low 60's
11. Service Engine Light while running?- on/off/intermittent
intermittent
11a. Service Engine light does glow during start/cranking/bulb check: Yes/No
yes
12.Have you scanned for engine codes? Yes/No
yes
12a. List exact results on
engine codes.
listed above. First set unknown how many were old (existing before incident) currently no codes after clearing
13. Condition of Battery terminals (removed, cleaned and tightened).
New New battery cables 2/0 main pos and neg 4awg to alt, junction box, and fender grounds added cable from alt
to second battery
14. Known condition and age of Batteries.
new
14a. Are batteries a matched set of same age?
15. Condition of
Major Grounds (removed, cleaned and tightened)
removed, cleaned, tightened
15a Have the batteries been
individually load tested?
Yes
16. Does engine crank, or "turn over"?
yes
16a. Does engine start and run?
no
17. If engine does not start-
Crack injector line: do you have fuel? Yes/No
yes
18. Does your Wait To Start light come on?
yes
18a.Number of seconds WTS light is lit.
varies
19. Engine Cranking speed (if you have an accurate tachometer).
think ive seen it 800-1000 rpm
20. Are you experiencing Stalling?
no
20a. Describe the event (upon startup only, down the road, hit a bump, etc...)
see above
20b. Do you notice loss of dash or instruments?
no
21. Check turbo inlet and air filter for obstructions.
clear
22. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now?
no staret hot or cold
23.
Lift pump test - Describe results.
16oz in 40 sec at drain 9 psi at IP
Answers for 24-26 were from when truck would start
24. Upon cold start, does the radiator hose get hard quickly? Yes/No
no
25. Upon cold start, do you have excessive white smoke? Yes/No
no
26. Do you have excessive cranking time before the engine starts? Yes/No
no
27. Have you used the block heater? Does it affect engine starting? (only try for starting problems).
Yes, once during diagnostics no affect
28. Are all glow plugs in
proper working order?
Yes, all plugs pulled and bench tested. A couple were tested hooked to wiring harness and worked properly.
29. During hard acceleration, do you have excessive black smoke? Yes/No
no
30. Do you have any unusual exhaust smoke issues?
no
31.
Turbo check out - Pass/Fail
NON TURBO TRUCK
32. Indicate fuel that you are using: Bio-Diesel, #2 Diesel, SVO/WVO, other
#2 diesel
32a. If running Veggie Oil fuel setup, indicate details of your conversion (homemade or packaged system).
N/A
33. Are you using any fuel additives? If so, please list.
no
34. Upon unscrewing fuel cap, do you have a large vacuum formed in the tank? Yes/No
no
35. Do you have any service history available that might pertain to the problem you are having?
NO
36. Please indicate any modifications to the vehicle that might help us diagnose better.
Humvee intake, EGR removed, PMD relocated
DIAGNOSTICS PERFORMED
backup pmd installed at IP
voltages tested at PMD attached to extension cable good
FSO swapped
grounds cleaned
batteries replaced
battery cables replaced
glow plugs pulled and tested
glow plug harness tested
ignition switch replaced
lift pump jumpered during all testing
lift pump producing fuel
IP return line blown clean
swapped fuel relay
installed clear IP return line - no bubbles
