This isn't the top truck in the signature, hadn't updated it yet when you posted. The K3500 with manual trans dumped a head gasket.
I'd bought the 2500 w/o title since it had a good cab, fair bed and I needed to do a cab and bed swap. PO said it wouldn't start after he had a craigslist mechanic replace flexplate. When the 3500 went down, I put a starter in it and haven't had a problem starting it. In fact it ran good. When doing a tune up I found someone had busted an ear off the distributor. Currently in shop getting that replaced. Got a title and decided to keep it on the road.
I found the C1500, was supposed to run good, reverse slipping, body in very good shape. Bought it as a parts truck, motor incase block/heads in K3500 cracked. K3500 needed doors, C2500 needed fenders bed from C2500 was going to K3500 and C1500 to C2500. Put the 1500 on the road while getting the 2500 ready. Found out a nearly bald rear tire was causing the limited slip to engage, guess this is what the PO thought was a trans slip. Hasn't slipped since I stuck a couple decent tires on it. Truck is too nice to part.
Now I'm stuck with none of them working.
