That's a setup worth it's own thread with pictures. Vans are rare on here with the 6.x engines.
Not sure what the embarrassment is all about. Only rust through would look worse than the Rat Rod Patch. Landscapers drive better looking trucks out here. "Been there, done that, Run that over..." Seriously going through "Little Mexico" with a cargo trailer is a hoot with all the kids wide eyed looking at Patch.
Paint doesn't make it go faster or improve MPG towing.
Oil temp control???
I frequently burn up oil cooler lines and have been known via UOA to ruin engine oil via getting it too hot. Evaporating off 1 quart every 500 miles is normal IMO on a 6.5 out here. GM adjusted their "Low Oil Pressure stop engine" alarm by adding a longer "buffer" before it went off due to our and a few other Duramax owner problems with the alarm going off. Oil temp: It's all good till you scuff a piston. I run semi Synthetic Mystik 15w-50 and should run full synthetic. On hot summer days in excess of 115 degrees it makes a difference via higher oil pressure vs. Shell Rotella 15w40. At this time this difference is keeping me from having to pull the engine due to low oil pressure. I find synthetic gets me better oil pressure in general when hot. At 2500 Mile oil changes done weekly the synthetic was out of budget esp. when having to add 5 quarts over the said 2500 miles. 3000 Mile oil changes were ugly on the UOA reports. Gapless rings changed things on the UOA.
IMO They don't release turbo specs as someone would attempt to copy it and make a "knock off" or go direct and obtain the turbo from the OEM.
Oil temp control???
