Ok, not charging is one thing. A drain overnight is another. It is possible the same damage could be causing both.
Chasing intermittent electrical problems is the hardest flipping thing. Having good tools for chasing the problems can save hours, days even. There are jury-rig ways of finding opens and shorts like using a compass, but learning it on a hard problem is nearly impossible. My suggestion is bite the bullet and get the best tools to do the job, then you have it for years to come.
here is quickest search to pop up, maybe look for a better price, but nothing out there gives faster results for someone that doesnt have a decade of chasing them.
http://www.tooldiscounter.com/ItemD...3Uw07FKL2MK27bTTi2HRlNCF9FZAS4ETNhxoCRuvw_wcB
You can try having someone watch the gauge while you go around shaking the wire harness. When you shake an area and the gauge starts being affected, tear into that part of the harness.
Adding more wires to bypass can be done, but you have to abandon the damaged harness area. Otherwise if a short is still there you can just catch the harness on fire. Ive seen many a rig burned to the ground over this. Once you supply backfednpower to a circuit that no longer blows a fuse and quits feeding- there is no safety anymore.
If you absolutely have to run temporary wire to bypass, disconnect the battery every time you shut off the truck. Have a fire extingusher next to you in the cab. Be ready to disconnect the battery at a moments notice.
As for where to look for the problem, you need to follow the harness from the battery to each end of the charging circuts.
